Save £24 - Book Now!Hi,
I'm looking to build a double garage 5.6m wide by 5.3m deep. I am reusing some timber roof trusses; so I will need to span a purlin with a width of 5.6m on which to rest the 4.2m long roof trusses.The trusses are 38 degrees in pitch and from the internal span beam, the truss will then further extend downwards in the same pitch by 1.2m - giving a front roof section of 2.1m to the ridge and then 3.2m to the rear with the supporting purlin at 2.1 / 1.2m
The timber trusses are of 40mm softwood construction of a modified queen scissor type design - The roof will be covered in 12mm sterling board and have clay pantiles as the roofing material.
My question is; I'm thinking of using timber rather than a steel for the purlin -What size and grade of timber(s) should I use for the load bearing 5.6m span?
Thanks in advance for any help on this.
I normally associate purlins with a traditional cut roof where they pick up the mid span deflection of the rafters.
From your description above it sounds like you mean the beam upon which the trusses are going to rest and I would suggest you stick to steel for a span of 5.6m.
Really you need a structural engineer to appraise your design and provide you with calculations for each member and/or beam.
Good luck.
